engine vibrating + low performance - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 24 (permalink) Old 07-08-2013, 07:42 PM Thread Starter
Hi guys we have little problem in our 2009 Armada when the car is parked and i give it little gas from about 1000 to 1700 RPM the engine make vibration is it normal ?
and another issue sometimes i feel the car unresponsive ( like when the car on normal road then there is sudden a bridge the speed drop a bit and i give it more gas sometimes i feel like i'm about to press the accelerator all the way down to make the car downshifting ) :eek:
the car has about 95000 KM and the engine oil get change every 3000-4000KM and newly we changed the engine air filter and we use 95 octane fuel
what do u think guys ? is it spark plugs problem ? or somthing else ?
( sorry for my bad english )
yahyoh is offline
post #2 of 24 (permalink) Old 07-08-2013, 07:54 PM
AngelVivas's Avatar
I would probably suggest checking the Spark Plugs for sure. Hopefully someone else will chime in here with some insight. Good luck!
Angel Vivas, III
2006 Nissan Armada SE 4x2 Silver Lightning
UPRev Tuned (Cajun Style)
Gibson Cat-Back Exhaust
Cajun Catless B-Pipes
Volant Cold Air Intake
CSF 3328 Racing All-Aluminum Radiator
2" Front Leveling Kit (To Even Her Out)
Bilstein HD Front Struts
Interior LED Kit
6000 HID Kit
Nissan Black Grill Guard
AngelVivas is offline
post #3 of 24 (permalink) Old 07-08-2013, 07:58 PM
blackArmada_Dxb's Avatar
A good fuel/Injector cleaner should be the first thing you should do on your Armada. Most of them on the market are junk, so stick to either SeaFoam or Royal Purple Max Fuel Cleaner. They work very well.
My Build Thread:
blackArmada_Dxb is offline
post #4 of 24 (permalink) Old 07-08-2013, 08:12 PM Thread Starter
Thank u guys
i will try fuel injector cleaner if didn't work then i think we should check spark plugs soon
yahyoh is offline
post #5 of 24 (permalink) Old 07-08-2013, 08:21 PM
You must have platinum spark plugs. It might not hurt to replace them, but I guess ours is rated for at least 100,000 kms.
My Build Thread:
post #6 of 24 (permalink) Old 07-08-2013, 09:32 PM
Kooshtaka's Avatar
Quoted: 103 Post(s)
Could possibly be fuel sender?
'05 Mada LE Slate
Kooshtaka is offline
post #7 of 24 (permalink) Old 07-08-2013, 10:57 PM
Yeah fuel pump could also be a culprit, but let him try this $20 fix first.
My Build Thread:
post #8 of 24 (permalink) Old 07-09-2013, 12:38 AM
Best fuel injector cleaner is BG44K. It is what most mechanics use or at least ones I have talked to. You can't generally find it in stores, but you can find it on eBay. Each can is $24-30.00, but you do better on eBay. I just got 3 cans for 37.50 including shipping. Hoping to clear up my occasional p0174 error before throwing parts at the problem.
Sent from AutoGuide.com App
2007 LE, S&B CAI, JBA Long Tube Headers, Cajun Catted B-Pipes, Uprev, Bilstein HD, PowerStop Drilled / Slotted Brakes, DDM 5K 50W, BFG KO2, Garmin 1490T hardwired with
KMDColo is offline
post #9 of 24 (permalink) Old 07-09-2013, 12:49 AM
Kooshtaka's Avatar
Quoted: 103 Post(s)
Thought Nissan would pick up tab if it was fuel pump.....
'05 Mada LE Slate
post #10 of 24 (permalink) Old 07-09-2013, 01:49 AM
Really? How come?
My Build Thread:
