trans fluid in diffs? - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 5 (permalink) Old 11-06-2013, 11:17 PM Thread Starter
Well not really..
So I picked up an 06 with 62K and decided to do all the fluids. I drained the front and rear diff and then got my pump out and some Amsoil Severe Gear. I pumped the pump a few times and realized that I had last used it for the transfer case and there was still a bit of trans fluid in it (the amsoil trans fluid is used in the transfer case). So, I pumped about half a quart of the severe gear through it at which point I hadnt seen hint of trans fluid mixed in, and then I filled the front and rear diffs.
What I am wondering is, should I buy a new pump and drain and re-fill the diffs immediately? I am concerned that there could be some trans fliud contamination and maybe that could cause the severe gear to break down?
Any thoughts?
chrisleduc1 is offline
post #2 of 5 (permalink) Old 11-06-2013, 11:31 PM
audioXclusive's Avatar
I did the same thing about two years ago, right before my long trip from Chicago to Texas. So far and knock on wood, everything is been good.
audioXclusive is offline
post #3 of 5 (permalink) Old 11-06-2013, 11:37 PM
blackArmada_Dxb's Avatar
Yes you should drain and re-fill as soon as you can.
My Build Thread:
blackArmada_Dxb is offline
post #4 of 5 (permalink) Old 11-06-2013, 11:56 PM Thread Starter
Just to be clear, I didn't put anything into the diffs until AFTER I had pumped a half-quart through the pump and it absolutely no red tinge for a while..
post #5 of 5 (permalink) Old 11-07-2013, 12:19 PM Thread Starter
Per Amsoil:
"The small amount of ATF that may have been left in the pump is of no concern."
