Time to Change Tranny Fluid - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 16 (permalink) Old 02-12-2014, 05:53 PM Thread Starter
The Jonah's Avatar
Greetings all,
I have an 08 with 68,000 miles and finally decided to change the tranny fluid myself. I could be long overdue, but I havent noticed any slipping, but i feel its time.
I have scoured the forum and read and re-read every thread regarding a tranny fluid drain fill, pan dorp etc. I have a few NOOB questions/concerns as I have never done this so please bear with me:
1. Fluid type: I am leaning towards oem nissan fluid, but there are 2 types, S and J. I have cal;le dteh dealership asking for a price and they decided to go back to J, well its like $12 a qt. What are you thoughts on this? At my mileage, is there another alternative that would not affect performance?
2. Drop Pan: If i drop the pan, how do I clean the inside? Am I using a cleaner (ie: degreaser, solvent), or do I just do a wipe down and then reinstall? I also plan to re-use the gasket if it doesnt look terrible.
3. Intervals for initial drain fill: Would it be adviseable to do the drop pan/clean and then fill...drive around and then re-do it? If so, how many miles in between and woudl you re-use fluid, or use all new?
Can someone please chime in? Additional advice is appreciated.
I am replacing my front and rear bushings when weather permits and so I am now in 'maintenance mode'...thinking of other things to do, and this is top on the list.
Thanks in advance brotheren.
The Jonah is offline
post #2 of 16 (permalink) Old 03-01-2014, 11:55 AM
Eagerly awaiting a seasoned veteran's advice on this. Need to do the same.
2019 Armada SL - Pearl White
austin_asu is offline
post #3 of 16 (permalink) Old 03-01-2014, 01:10 PM
Kooshtaka's Avatar
Quoted: 103 Post(s)
There is a terrific write up on here that'll answer several of your questions. Have you tried searching for "fluid change"?
'05 Mada LE Slate
Kooshtaka is offline
post #4 of 16 (permalink) Old 03-01-2014, 04:07 PM
1. S replaced J. I think S is the same price.
2. Drop pan, wipe with lint free rag. I reused my gasket.
3. I dropped, I didn't redo until it's time again. I wouldn't reused oil.
Manual said to do it when the engine is hot/warm. Turn the engine on 10 mins, let cool for 10 mins then drain. Be careful it's still hot liquid. Fill and read when the engine is warm also.
sent from broken autoguide app.
post #5 of 16 (permalink) Old 04-25-2014, 01:00 PM
regdawg's Avatar
Quoted: 71 Post(s)
I just changed my tranny fluid along with my differential fluid at 97K. What is the normal interval to change out the fluids again?
2008 Armada SE - charcoal leather, comf & conv package, tow package, back-up camera, power lift gate, bose stereo
Upgrades so far
*Billet Grille
*Hood Protector
*Bilstein HD front struts
*K&N Air Filter
*Garmin Mechanic HD
*5000K HID's Lows/Fogs
*Steelcraft 3" nerf bars
regdawg is offline
post #6 of 16 (permalink) Old 09-17-2014, 06:35 PM
I also just changed my diff fluid and glad I did it was over filled and was "Burnt" from what I could tell I replaced with 75w140 penzoil synthetic.
Now i want to change my trans fluid and I am also curious as to what would be a good replacement fluid or to just stick with the oem stuff.
Mmike is offline
post #7 of 16 (permalink) Old 09-17-2014, 09:04 PM
Quoted: 96 Post(s)
Trans fluid is usually 30k mile interval. I am overly cautious and change 10-20k miles. Rear diff around 10k then every 50k after that (i do 20k).
Fluids, I stick with oem (matic s) up to warranty then a good quality synthetic like amsoil. I know magnuson moss (sp) lets you use other fluids, but lawyers are expensive if they deny coverage.
5150ds is offline
post #8 of 16 (permalink) Old 01-04-2015, 02:16 PM
regdawg's Avatar
Quoted: 71 Post(s)
I did a drain and refil with my Tranny (S Fluid) and replaced my differential with synthetic stuff all at 97K. Would it be safe to wait until maybe 120K to replace these again? I rarely tow anything at all.
Upgrades so far
*Billet Grille
*Hood Protector
*K&N Air Filter
*Garmin Mechanic HD
regdawg is offline
post #9 of 16 (permalink) Old 01-05-2015, 12:58 PM
You'll be fine.
The majority of my driving is in/out of NYC, stop n go traffic for the most part. I routinely drain and fill the drivetrain fluids every 30K; although I did a complete drain and fill, removal and cleaning of the transmission pan at 80K.
Closing in on 162K and no issues with the drivetrain.
post #10 of 16 (permalink) Old 07-30-2015, 10:51 AM
regdawg's Avatar
Quoted: 71 Post(s)
Planning to do a drain/refill in a couple weeks, how many qts usually get drained? I forgot, need to order the fluid.
Upgrades so far
*Billet Grille
*Hood Protector
*K&N Air Filter
*Garmin Mechanic HD
regdawg is offline
