need diff help - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 3 (permalink) Old 04-27-2014, 11:45 PM Thread Starter
need diff help
09 armada,bearing went on my front diff driver side stub shaft. After removing diff and opening the back, how do i get to the c-clip inside? do you have to pull the ring gear out first?
duckarse is offline
post #2 of 3 (permalink) Old 04-28-2014, 12:58 PM
No need to open the differential. Use a puller or tap on the shaft flange to remove the shaft. The clip stays on the shaft.
When re-installing the shaft tap on the shaft to seat the clip. It will snap in place.
post #3 of 3 (permalink) Old 04-28-2014, 03:02 PM Thread Starter
thanks, makes a lot more sense then what i was told by the nissan dealership. when i open it i expected to see clips like other diffs but not this one.
duckarse is offline
