My front differential - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 6 (permalink) Old 06-11-2014, 03:25 PM Thread Starter
We have a 2013 Nissan Armada that I purchased last year at the end of May. At about 4k miles in the fall sometime, I drained and refilled the front and rear diff with Amsoil Severe Gear 75W-90 to get out all of the break in metal out of the fluid. It has about 14k on the clock now.
My procedure:
-Remove the fill plug to make sure I could get it off before I drain
-Remove the drain plug and empty the old fluid
-Put the drain plug back in
-Fill until it comes out of the fill hole
-Wait for it stop draining from the fill hole and replace the fill plug. Done.
Since then it has driven all over
-December 2013 Indianapolis to Orlando straight, sat for a week, then back from Orlando to Indianapolis straight.
-October 2013 Indianapolis to Mackinaw, MI and back again.
-Multiple trips from Indianapolis to SE Michigan.
-Multiple trips from Indianapolis to Cincinnati (Kings Island) last summer.
This year it has gone to Cincinnati once before as well (it was cooler and the wife was driving it so it most likely a less aggressive trip). The second time was this past Saturday. When we got home, I could smell diff fluid from something. I slid under the mada and saw fluid dripping from the drivers side lower control arm, inside the wheel well looking like it was coming from above from a plastic push pin and multiple other places. So I looked into the engine compartment and under the abs distribution block was all wet as was the space between it and the airbox.
After doing a little more research, I see that the front diff's vent tube goes up next to the airbox. Now it makes sense how I am seeing fluid where I see it. I am still unsure as to why it would have vented so I took it in to the dealer on Monday.
They looked it over and said they couldn't find anything wrong with it. They checked the fluid level and said it was full and they didn't add anything. They said it was probably overfilled from the factory and with it being a hot day, it must have expanded as it heated in to the vent. Knowing I did the last fill, I just took it back since they just inspected it, said it was fine and documented me taking it in.
Now, I am looking for someone to tell me why - how this happened? How could it go almost 10k miles since I changed it and all of the sudden it vents? How could there be too much with my fill procedure. As I recall, when I opened up the fill plug, a little bit of the old fluid started coming out (a couple drips). So when I refilled it, it would have been the same level.
Could the extra volume be water - condensation from the hard winter adding volume and it not burning it off before it got hot and expanded? Is the Amsoil adding volume as it shears?
I've got 8 quarts of Valvoline SynPower 75W-90 on the shelf. Should I dump the Amsoil from both diff's and replace it with the Valvoline?
I'd love to hear your opinion on how my front diff magically added volume to the front diff and needed to vent it.
13 Armada Platinum 4X4
13 Mustang GT Premium
87 300ZX Turbo
85 Yamaha XV1000
BobThe is offline
post #2 of 6 (permalink) Old 09-30-2014, 03:35 PM
Front diff vent tube
Yes, short hauls will build water foam residue in the tube, which collects dust and clogs. Next, if you change the front fluid often, you will see the white foam in the diff fluid when you drain it. You can also get bugs crawling into the tube and blocking it. Your procedures are correct. The other thing to look at is if you have any leakage where the axle shaft enters the diff.
My procedure:
post #3 of 6 (permalink) Old 11-18-2014, 08:31 PM
F4N4EVR I have the leak where the axel joins. What is up with it? Thank you for any help.
Sfdefender25 is offline
post #4 of 6 (permalink) Old 12-09-2014, 09:42 PM
Yes covered by warranty
Had leak from front diff breather hose
Indy is offline
post #5 of 6 (permalink) Old 12-09-2014, 09:45 PM
I have a 2011 Armada I bought new and it now has 110k on it and the front diff hose started to leak (overflow) two months ago
Very annoying, dealer said it was normal. Oil all over the driveway.
Indy is offline
post #6 of 6 (permalink) Old 12-10-2014, 11:25 AM
You'll need to replace the cv flange seal(s) on the front diff housing. Since the axles and cv flanges have to be removed, replace the circlips at the end of the cv flanges that "lock" into the front diff.
I paid less than $50 for the seals (driver & passenger sides) and two new circlips.
