Transmission failures - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 15 (permalink) Old 06-18-2014, 01:09 PM Thread Starter
KingRJ's Avatar
Quoted: 33 Post(s)
Thumbs up Transmission failures
Just thought I would give everyone a heads up, I have just rebuilt\replaced my 5th tranny on an Armada. Water intrusion was the cause EVERY time including two that I was able to save. Leaking trans coolers in the radiator was the cause! Just some advise if you are at or over the 80k mark I highly recommend either radiator replacement or install an aftermarket trans cooler and take the radiator out of the loop. By the way 2 times I had to have the fluid analyzed to find the water intrusion as I did not see anything unusual! HTH
KingRJ is offline
post #2 of 15 (permalink) Old 06-19-2014, 12:32 AM
yeah..i have the stillen aluminum rad now and a trans cooler also. i did it as a precaution.
post #3 of 15 (permalink) Old 06-19-2014, 12:18 PM
drewcs's Avatar
Didn't want to hear that. So would you say the aluminum rad is a better bet even if i dont do the bypass.
'06 LE, Airaid MXP CAI w/dry filter - BullyDog GT w/regular tune - 20" Titan wheels w/Cooper ATP's - Int/Ext LED conversion - 5000K HID low beams - Bilstein HD - Amsoil Synthetic everywhere - Power Stop drilled/slotted rotors w/ceramics pads
drewcs is offline
post #4 of 15 (permalink) Old 06-19-2014, 12:31 PM
Quoted: 72 Post(s)
Absolutely!!! After reading on here about radiator failures I changed mine to a Stillen as a precautionary measure. Cheap insurance, the cost of a radiator vs. tranny. Even if dealer or independent repair shop does it you come out ahead. The radiator is less than an OEM and is a better radiator FWIW.
E&J push'n wind is offline
post #5 of 15 (permalink) Old 06-19-2014, 01:47 PM Thread Starter
KingRJ's Avatar
Quoted: 33 Post(s)
Probably any replacement readiator is better than the original, however I recommend installing an aftermarket cooler and eliminate radiator as a potential failure.....awful cheap insurance and just about anyone can install it!
KingRJ is offline
post #6 of 15 (permalink) Old 06-19-2014, 02:43 PM
drewcs's Avatar
Ahhh...the upgrades continue... Thanks!
drewcs is offline
post #7 of 15 (permalink) Old 06-19-2014, 02:45 PM
drewcs's Avatar
I don't tow but do carry a full load often. My only concern with the bypass trans cooler is that I live in a cold climate and worry about the warm up. Is this an issue I should or shouldn't worry about?
drewcs is offline
post #8 of 15 (permalink) Old 06-19-2014, 03:14 PM Thread Starter
KingRJ's Avatar
Quoted: 33 Post(s)
Cold trans fluid is not really a problem it will warm up very quickly on its own......the trans cooler is for cooling fluid to 200 or so degrees not for warming it up.
KingRJ is offline
post #9 of 15 (permalink) Old 06-19-2014, 04:20 PM
Wrap a towel around the transcooler like nightowl does when he start it up in the cold morning.
post #10 of 15 (permalink) Old 06-20-2014, 06:28 PM
drewcs's Avatar
Just wondering how much longer it would take to bring up to operating temp.
drewcs is offline
