Can I change the vavle seals without puling the head on Armada - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 7 (permalink) Old 08-09-2016, 09:46 AM Thread Starter
Just bought a 2013 Nissan Armada and the valve seals seem to be bad. (going to do a test this weekend to be sure) .
does anyone know if the seals can be replaced on this one without pulling the head? or engine?
marcus allen is offline
post #2 of 7 (permalink) Old 08-09-2016, 06:14 PM
Rumplecat's Avatar
Quoted: 44 Post(s)
Smoke on startup?
Rumplecat is online now
post #3 of 7 (permalink) Old 08-10-2016, 07:00 AM
is there any smoke when u start the engine???
JBA LT HEADERS
CAJUN BPIPES
TRUE DUAL MAGNAFLOW CATBACK
UPREV
AIRAID CAI
STILLEN 3 ROWS RADIATOR
TRUE COOLER TRANS BYPASS
PML DEEP OIL PAN
JWT CS2 CAMS & Valve springs
TRANSGO SHIFT KIT
EBC ROTORS FRONT & BACK
HAWK PADS FRONT & BACK
STAINLESS STEEL BRAKE LINES FRONT & BACK
NEXT MODS HOPEFULLY
VENOM 102 MANIFOLD
LEVEL 10 FULL BUILD TRANNY.
2009blackbeast is offline
post #4 of 7 (permalink) Old 08-12-2016, 10:56 AM Thread Starter
Yes, there is a blue smoke upon startup.
and it burns through about 1 qt per 250 miles..
Previous owner must have abused it
post #5 of 7 (permalink) Old 08-12-2016, 01:32 PM
Any chance the blue smoke disappears after warming up or is it consistent while driving?
I had a similar issue a couple years ago and the culprit was a spark plug tube gasket. It had worn out and was letting oil seep through the 1st plug/cyclinder. Unfortunately, Nissan doesn't just sell the gasket individually; I purchased two new valve covers and problem solved. I'd also check the PCV valves as those are usually overlooked and can cause unwanted oil leaks and sludge buildup. An old way of testing them is after removing them from the valve covers, give them a shake and listen for a consistent rattle.
post #6 of 7 (permalink) Old 08-13-2016, 01:17 PM Thread Starter
Sounds like worth looking into. The smoke does disappear while driving... but it still burns through a lot of oil.
Is there a way to check the spark plug gasket? Or just replace the valve covers?
post #7 of 7 (permalink) Old 09-04-2016, 03:14 PM Thread Starter
Sept 3 update--- Thank you very much for replying.. i ordered & replaced the valve covers (which comes with the PCV valve and spark plug tube gaskets and it did the trick!
No more oil leak or blue smoke
Thanks again
