Anyone installed manifold/converter bank 1 yourself ? - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 7 (permalink) Old 11-05-2017, 03:49 PM Thread Starter
2004 needs new bank one converter which is the one on attached to the manifold. The Nissan dealer told me i could buy one from RockAuto, ebay or wherever and they would install it for around $300. I have found several in the $180-350 range online. Not 100 percent sure on which brand to buy. Suggestions would be appreciated on that too! However im trying to save all the money i can with Christmas right around the corner. Ive watched a couple youtube videos and read several threads on how to do it. I honestly see it being a pretty tough job and expect having trouble with a few bolts being stubburn, hard to reach etc. I've done harder things on vehicles but the work space is scaring me a little on this job. I just wanted to see if you guys thought it would be worth doing myself or at least attempting always knowing i can just load it up on trailer and take 15 minutes down the road to the dealer if i cant do it myself? I was really suprised when they said labor would only be around 300 and they would install a non-Nissan part. Thoughts would be greatly appreciated!
browntown3 is offline
post #2 of 7 (permalink) Old 11-09-2017, 09:01 AM
rsoto80's Avatar
yes i have installed manifolds myself, but i used low mile nissan manifolds from a nissan titan so i can't comment on the aftermarket factory manifolds. As for the job, it is not that bad and in my opinion the hardest part of the job was taking the heat shield off the manifold. The bolts are tiny, i think 10mm, but are rusted and tight...after getting the bolts off the heat shield you have to bend the chit out of it to get it out which is difficult given the space you have to work with. Other than that it's not that hard, just takes a little innovation to budge some of the manifold bolts loose. Also, this part might scare you as it did for me, but you have to raise the engine a few inches in order to take the manifold/cat assembly off. Just loosen the left and right engine mount bolts but don't take them off or you will have trouble threading them back in. while the engine is lifted enough, pull the old manifold off and slip the new one on. Fasten some bolts to secure the new manifold and you can lower the engine back down. You can tighten the engine mount bolts back. Just install everything back in reverse order.
04 Nissan Armada all stock
06 Dodge Charger R/T
[email protected]
rsoto80 is offline
post #3 of 7 (permalink) Old 11-09-2017, 03:13 PM
charlie1978's Avatar
Quoted: 28 Post(s)
Is that your video at youtube?i watched it 4x(i watched it yesterday for the last time)..need to help a friend on his titan before he gets crazy.
charlie1978 is offline
post #4 of 7 (permalink) Old 11-09-2017, 03:15 PM
Quoted: 28 Post(s)
post #5 of 7 (permalink) Old 11-09-2017, 03:34 PM
rsoto80's Avatar
no. i wasn't aware they had a video on youtube for this job.
[email protected]
rsoto80 is offline
post #6 of 7 (permalink) Old 11-09-2017, 11:13 PM
SGreenlyn's Avatar
Quoted: 68 Post(s)
One thought is:
Definitely get the cats out of the manifolds, especially in a non emissions state. They'll only present a continuous problem and a potential threat to the life of the engine. I'd go for long tube headers as a starting point (some stainless long tube headers go for as little as $200/pair with good reviews), then figure out what your state requires as far as cleaning up the emissions. If no emissions reqs, get an AFR reading to confirm you are close enough, then you're done forever.
Wish there was a better answer.
2005 Armada LE 207K miles,
with 6000K 75W HIDs,
SGreenlyn is offline
post #7 of 7 (permalink) Old 11-10-2017, 09:14 AM
seymore4's Avatar
Quoted: 22 Post(s)
Originally Posted by SGreenlyn View Post
One thought is:
If you don't have emissions testing the cheapest permanent fix is headers and uprev tuning. With headers you really do need the tune. If you're state requires an OBD2 scan for emissions testing then you also need catted B pipes to keep the CEL off. Replacing anything past that is up to you.
Uprev Guru for Cajun B Pipes
seymore4 is offline
