Catalytic Converters - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 6 (permalink) Old 02-24-2018, 07:20 PM Thread Starter
I have a 05 Armada need to replace OEM Catalytic Converters any suggestions out there to replace the OEM with after market?
gforce is offline
post #2 of 6 (permalink) Old 02-24-2018, 09:08 PM
the one that is California carb legal is magnaflow. Not sure where you're located at.
Sent from my MHA-L29 using Tapatalk
post #3 of 6 (permalink) Old 02-26-2018, 06:49 AM
carid's Avatar
Quoted: 13 Post(s)
Hi there, here's the list of catalytic converters we've got for the '05 Armada:
2005 Nissan Armada Catalytic Converters
If you are in California, the majority of these converters will be illegal to use, as you need one that meets CARB requirements. If so, you should use either Magnaflow converters (here's the link to see the selection) or OEs, that you can order from the dealership.
Hope this helps!
Nissan Armada
Call Toll Free: 800.505.3274 |
carid is offline
post #4 of 6 (permalink) Old 02-26-2018, 10:31 AM
seymore4's Avatar
Quoted: 22 Post(s)
Aftermarket manifolds are going to fail again... give us a call for the only 100% proven fix.
Cajun Bpipes | shreveport, LA 71129
Uprev Guru for Cajun B Pipes
seymore4 is online now
post #5 of 6 (permalink) Old 02-27-2018, 09:59 PM
I need a new drivers side manifold as well. Does anyone know the labor hours to replace?
rpenlington is offline
post #6 of 6 (permalink) Old 03-01-2018, 03:40 PM
Depends on where you live. According to diy members a 4x2 vehicle should be take around 4 hrs and 4x4 is around eight hours for both side. I had long tube headers done by a Nissan tech in around 4 hours and mine is 4x4. I paid like 400 since is under the table work. You might change both side chances are the other side might have a crack that can't be seen. Or it will crack sooner or later. There is a high chance of oem cracking again
