need suggestions on possible head gasket - Nissan Armada Forum: Armada & Infiniti QX56 Forums
post #1 of 3 (permalink) Old 04-01-2019, 09:44 PM Thread Starter
my 06 LE is smoking white from exhaust and milky in valve covers but not oil. this the head gaskets?
James Smith is offline
post #2 of 3 (permalink) Old 04-11-2019, 07:25 AM
Firefighter1406's Avatar
Those defiantly lead me to be suspicious. How far do you drive to work? I know creamy oil under the oil cap can be from excess moisture, not getting the vehicle really hot and warmed up. Frequent trips like this will start to get a lot of moisture buildup in the engine.
Firefighter1406 is offline
post #3 of 3 (permalink) Old 04-11-2019, 10:37 AM
Firefighter is right. You can have oil under the cap. It's fairly common if driven for short trips quiet often and the engine isn't given a chance to burn off the condensation that builds up. It's supper common of propane forklifts.
How much is it smoking, is it puffing out huge thick white clouds? Hows the oil on your dipstick? To be sure you have coolant in the oil you could let it sit overnight then pull the oil plug (messy and hacky)and see what comes out first. Water is heavier than oil and will settle to the bottom. Are you having overheating problems? I'm not sure about Nissan's but depending on how the gasket or head failed sometimes you can pull the rad cap(when it's cold) and the coolant bubbles like mad then that's a sign you may be pumping compression into the coolant passages.
04 Armada LE
fummins is offline
Questions on diagnosing a blown head gasket. James Smith Engine/Drivetrain 1 04-01-2019 07:23 PM
Low coolant - head gasket? jiriki Problems 9 02-02-2016 02:29 PM
My Head Gasket Journey... apamburn Engine/Drivetrain 0 07-03-2015 05:08 PM
Head Gasket?? vanek15 Problems 10 02-23-2015 04:58 PM
Whats your quote on how much a head gasket.. ronnieramos General Discussions 0 07-24-2008 02:54 PM
