Hello all, I have recently purchased a 2004 Pathfinder Armada LE and the original owner had the Air Shocks removed and replaced with stock shocks because he was tired of replacing them. The rear suspension was a rusted mess so I just installed all new control arms, springs, etc and continued to use the aftermarket basic shocks in the back. It appears when pulling a trailer the rear sags too much so I want to go back to the air leveling shocks. I have access to the 2004 service manual and have verified the fuses 12, 14, 19 in cabin as well as 9 and 29 in the engine compartment. I noticed that the compressor image in the manual shows the relay being part of the compressor, but this is not true (or at least not visible) - parts.nissanusa.com indicates all models 2004-2009 have the same compressor part number so then when I looked at relays for 2004 it shows 1 relay (25237-EA000) behind the battery for the air suspension. I was able to swap relays and still not working. Next I used a volt meter and confirmed continuity where there should be, but for voltage on pin 2 for the compressor harness I see only 7.5 volts (IGNITION OFF) and 8.5 volts (IGNITION ON) when there should be 12 Volts on that line. Looking at the Suspension Control Unit buried behind the drivers side rear panel in the 3rd row seat I was able to test inbound harness voltage to this unit, and pins 6 & 7 are a little hot at ~14Volts when I should haver 12 volts.
That being said with only 8.5Volts out of the suspension control unit (28581-7S600) I am assuming it is the issue and found a USED ebay one for $50 as the revised part 28581-7S602. While I wait to receive this unit I wanted to reach out to see if anyone else experienced this low voltage issue to the compressor from the suspension control unit before and what their fix was. Thanks in advance.
