Yes.. they have aftermarket compatible. How much is the dealer asking? You can get ones at RockAuto for about $25 bucks each. Relearn Type 315MhzHello,
Am getting new tires and the dealer said they have a generic for all cars. Seems odd. Is this correct, really need to replace these sensors. They are original.
Thank you.
Have to use theirs, the guy said they have a box full and 'they aint too bad, maybe 35 bucks tops" so I'll let you know Friday/Saturday. Thank you very much.Yes.. they have aftermarket compatible. How much is the dealer asking? You can get ones at RockAuto for about $25 bucks each. Relearn Type 315Mhz
Shoot... Good LuckHave to use theirs, the guy said they have a box full and 'they aint too bad, maybe 35 bucks tops" so I'll let you know Friday/Saturday. Thank you very much.
Shoot... Good Luck
Shoot... Good Luck
Went to Rock Auto (on line) to look around. Under 2004, they do not list a Pathfinder Armada, they do show a 5.6L V8, but parts dont seem to match. Would like to pick up a few spare parts.Shoot... Good Luck
Start here Nissan Parts - Genuine OEM Nissan Parts and Accessories Online it's best to shop with them by using your VIN number to get the most accurate parts. It's all OEM parts a bit expensive but still cheaper than dealer. Also try Autozone.com. I would say as a very last resort amazon and ebay. I only use the last two for price checking. they have been known to sell counterfeit and low quality parts. Hope this helpsWent to Rock Auto (on line) to look around. Under 2004, they do not list a Pathfinder Armada, they do show a 5.6L V8, but parts dont seem to match. Would like to pick up a few spare parts.
Any other places you recommend?
I guess the VIN is the best way to go for this. I have resisted doing this but its probably more accurate. As far as Ebay, shopped there once, got screwed, they permanently lost a customer.Start here Nissan Parts - Genuine OEM Nissan Parts and Accessories Online it's best to shop with them by using your VIN number to get the most accurate parts. It's all OEM parts a bit expensive but still cheaper than dealer. Also try Autozone.com. I would say as a very last resort amazon and ebay. I only use the last two for price checking. they have been known to sell counterfeit and low quality parts. Hope this helps
Have you tried looking under the 2005 Armada section to see if parts match?Went to Rock Auto (on line) to look around. Under 2004, they do not list a Pathfinder Armada, they do show a 5.6L V8, but parts dont seem to match. Would like to pick up a few spare parts.
Was wondering about the spare tire tool kit. Mine is different from the other years and while the 2005 tip looks the same nissanusa says it will not fit the 2004. The 2004 Pathfinder Armada is the same vehicle and the 2005 so dont understand why they are different. PIA!Is there a specific spare part you are looking for?
Which part is different? The Jack?Was wondering about the spare tire tool kit. Mine is different from the other years and while the 2005 tip looks the same nissanusa says it will not fit the 2004. The 2004 Pathfinder Armada is the same vehicle and the 2005 so dont understand why they are different. PIA!
Not the jack the spare tire raising and lowering tools.Which part is different? The Jack?
Reason I asked is... I only saw the jack as being discontinued @ nissanpartsdeal.com but you can get the rest here Tool Kit & Maintenance Manual - 2004 Nissan ArmadaNot the jack the spare tire raising and lowering tools.
Nissan USA shown the 2004 Spare Tire Tool Kit as a Tee rod an extension and a lug wrench that also acts as a spare tire lifting and lowering crank.
The 2005 and up show the tee + 2 long extensions.
Anyway, I'll ask at the dealership tomorrow since I am unable to lower the space.
Assume the Rock Auto sells sensors, think I'm going to replace some since the car is starting to act up a little and I'm going to keep it.
Thanks.
In what way is your beast acting out of the ordinary?Not the jack the spare tire raising and lowering tools.
Thanks.
Admiral Chester Nimitz, Fleet Commander of the Armada (Chester to his friends), occasionally will turn on his Brake light/VDC off light/Slip light and leave them on for 10 minutes to two weeks, then turn them off. Nothing is wrong, just the lights are annoying (understand one sensor is acting up but no idea which one or where). My back up sensors are acting up and I do use them so thought I’d replace all 4.Reason I asked is... I only saw the jack as being discontinued @ nissanpartsdeal.com but you can get the rest here Tool Kit & Maintenance Manual - 2004 Nissan Armada
Hope this helps
Does Chester have the type that shows you tire on all four corners? Do he have both front and rear obstruction sensors?Admiral Chester Nimitz, Fleet Commander of the Armada (Chester to his friends), occasionally will turn on his Brake light/VDC off light/Slip light and leave them on for 10 minutes to two weeks, then turn them off. Nothing is wrong, just the lights are annoying (understand one sensor is acting up but no idea which one or where). My back up sensors are acting up and I do use them so thought I’d replace all 4.
If you are talking about the ABS Actuator and electric Control Unit its the brain for your ABS, TCS and VDC. It's located right beside the brake master cylinder. Here is the FSM for your Vehicle brake system. You can read up on it while to wait to take Chester to the dealer. Lets see what the dealer finds. Good LuckThe only Nimitz Beach that I'm aware of is in Honolulu, never been to the beach but I understand its next to the Coast Guard runway.
Anyway, there are 4 back up sensors, none in the front.
I did try and have the sensor replaced that causes the lights to come on, but it wouldn't act up in the shop. My understanding is there is only one sensor for the Brake light, VDC off light, and Slip light. but no one knows where it is.
As for the jack, if this one fails can always go to something else. The tee tool is another story.
I'll know more tomorrow, we'll see about the sensors, shame I just cant put the maintenance kit in for a buck.
This looks like something I am better off not futzing with. Pity, was hoping it was just a quick pop in pop out sensor. Thanks!If you are talking about the ABS Actuator and electric Control Unit its the brain for your ABS, TCS and VDC. It's located right beside the brake master cylinder. Here is the FSM for your Vehicle brake system. You can read up on it while to wait to take Chester to the dealer. Lets see what the dealer finds. Good Luck
Hello toame,This looks like something I am better off not futzing with. Pity, was hoping it was just a quick pop in pop out sensor. Thanks!
Does Chester your have the ability to recognize all four tire pressure and position? Or is it just a tire symbol light on the dash. Is your TPMS light of the dash blinking or soild ON?Hello toame,
The tire center did replace the sensors and told me everything was fine but, they are no longer on the bill and they will not activate. The technician asked me twice if this was a 2004 and I said yes but dont thing he wanted to mess with them.
I dont see any place on line on how to reset them myself, you have any thoughts on where I should look? Thanks.
Have 4 individual tire pressures but not positions.Did the tire center tell you what brand of aftermarket tire sensors they put on? There is a relearning procedure that should have done after the install.
No to brand. probably need to go back in person since not answering phone.Have 4 individual tire pressures but not positions.
Did find a Nissan video on how to do it with a paperclip, first set the tire pressures at 27, 30, 33, 36 and click your heals 6 times -- oops - ground the connection and it will reset. Can send you a link to the video. dont know if its factual but the video looks good.
Have 4 individual tire pressures but not positions. Did find a Nissan video on how to do it with a paperclip, first set the tire pressures at 27, 30, 33, 36 and click your heals 6 times -- oops - ground the connection and it will reset. Can send you a link to the video. dont know if its factual but the video looks good.
Do the relearn instruction you found or the on the thread I sent you... first. It should work.No to brand. probably need to go back in person since not answering phone.
