1 - 3 of 3 Posts
Today was the first time I replaced the spark plugs in the truck since Ive had it. The rear plugs were the hardest driver side more than the other due to the brake booster in the way. While changing the plugs I found out I need new valve cover gaskets and spark plug tube gaskets. I have two plugs that are getting oil into them.
If you're going to do the work yourself, here you go:
Nissan doesn’t sell the spark plug tube gaskets separately; only comes with new valve covers.
1 - 3 of 3 Posts
