My horn quit working after being down for timing chain, slides, and tensioner replacement. Also the starter was shorted to ground and got the negative cable really hot during crank test. Replaced ECM relay with recall relay in IPDM. Passes all IPDM tests except horn chirp test. Will not work in normal mode either. Ohm test reveals circuit intact from relay base to connector. No voltage to horn period.
Currently-No horn also-
No fog or parking lights, no front hvac compressor clutch engagement, front blower fan power locks, power windows, or headlamps.
Passes all IPDM test except horn chirp at initiation everything else works during test mode.
Any ideas I am time sensitive overdue for leaving the country and tied up with this problem unable to figure out anything. No IPDMs available at dealer nearest one three states away and $755 plus shipping. Not certain the horn test would invalidate the IPDM. Cleaned grounds on body and chassis. No codes everything works normal except the above.
HELP.
What year your truck?
To clarify all these don't work- fog, parking lights, front hvac compressor clutch engagement, front blower fan power locks, power windows, or headlamps. But when you run the test only the horn doesn't work?
Have you tried switching relays? mark them so you don't get them confuse where you pulled them from
Update- 2006 Armada LE
Horn does not work on IPDM auto active test IT DOES NOT CHIRP, nor blow on key fob alarm mode or manual push button on steering wheel. Everything else WORKS. Passes on all IPDM Autop active test except horn chirp upon initialization of test mode. Horn works when jumpered at relay base load side of contact with 12 vdc.
H1 horn relay base reveals continuity between coil side and ground as well as common side of contact.
15 Amp fuse has 12 vdc but also has continuity to ground on the upstream side of fuse holder.
Removed clock spring appears to be shorted to ground internally. Anyone seen this before? Did you have to replace IPDM also?
FYI- Starter shorted to ground previously.
Side effects- no headlights, fog lights, parking lights, windshield wipers, HVAC, front fan blower, power locks, power windows, no condenser fan, no sunroof. Passes all operations on IPDM auto active mode except horn chirp.
Fault 2-
Brake indication lamp
VDC off indication lamp
slip indication lamp
ABS indication lamp
Fault 3-
Rear suspension LL sagging
Fault 2-
ABS indication lamp
Fault 3-
I’m guessing you tested all the fuses. IPDM is usually associated with a crank but no start issue Does your car start? At this point might as well pull out the IPDM an inspected, check for burnt marks on the Board or burn smell. I would replace the relays since this issue was not there prior to working on it. Also IPDM from the dealership are non existing in my area
Changed clock spring and ipdm still fails horn chirp on auto active test or key fob or manual horn depress.
no headlights, hvac, wipers, power window, locks, sunroof, etc except works during iPads auto active test only.
im lost help Nissan technocrats
Replaced ignition switch contact side only, repaired a ground splice on underdash instrument panel, repaired a mickey mouse splice on ignition splice re-set ECU, still no horn, headlights, power window/locks, sunroof, front fan blower, hvac, or anything else basically but still cranks and runs without all lights etc. Anyone ever had a bad bcm, ECU give me some help here please this thing has eaten my lunch for a week now.
Still has brake light on, abs, slip, and vdc off indications and rear leveling is inop by visula inspection. Ima start on that tomorrow while I wait for help on this no horn issue. No horn chirp on auto active ipdm test everything else works on test...
HELP anyone out there at all with expereience on an 06 Armada LE or like auto...
ECU reset, TPMS reset, and checked all grounds, cleaned, and checked all connectors still no horn. Effin a it is time to bbq it I guess. Anyone want a nissan pos?
I was told it is a faulty BCM by an ECU sales rep. I guess it is time to take to the stealership for BCM, flash, ECU update, and ABS re-set. I did not receive any technical guidance or help from this site and for that reason I'm out.... I am going back to oilburners.com where real trucks reside. Thanks for nothing folk.
Dropped of @ dealer today
ABS, Slip, VDC Off, Air bag and TPMS flashing indications
Horn inop all modes
rear heater coolant leak underneath and behind rr tire
What say you for estimate?
Can they fix it correctly under $1K?
