1 - 3 of 3 Posts
Ok, guys ... I need your help. My blower is stuck on. The fan controls are not working (fan speed and on/off). Mode and temp controls both work fine. The display on the dash shows as if everything is functioning properly.
Any advice would be greatly appreciated! Thanks in advance! :)
I had a similar problem with my 05 Armada. On its own, the blower would turn off, or occasionally, rev all the way up and then turn off. AC and heat worked, but blower was wacky. Turned out to be Blower Motor Resistor, part was 137.00. Replaced the cabin air filter, climate control works great now.
the resistor is easier to tackle but over the years ive seen others have the issue and in troubleshooting it was the control panel, so keep that in mind if the resistor does not fix.
1 - 3 of 3 Posts
