1 - 2 of 2 Posts
Recently, the rear glass (button above the license plate) started working only intermittently. You press it and nothing happens the majority of the time and then sometime later, maybe 15 seconds or while driving it unlatches, like extreme delay. Sometimes the rear glass will be unlatched and you wont know until you try to open the rear hatch by pressing the handle under the license plate and realize it doesnt work because the glass is open.
Any ideas where to start, fuses, replace the whole component or take it to the shop?
Found part # 25384-zh60a from 100-200 on the web, if that would resolve it, curious if anyone has a walk through or has encountered this behavior before?
Thanks,
Michael
I have kinda the same issue, where the back glass will just randomly unlock, and then you can hear the lock trying to relock but won't it just keeps clicking...For as much as I use the back glass, I'm likely just going to unplug it so that it is always locked close.
1 - 2 of 2 Posts
