1 - 20 of 20 Posts
Hi all I have a 2008 qx56 when I drive over bumps in the road rear of the car seems to bottom out car sit even no sag its like I have no shocks but sits fine,
what stops the car from hitting chasis against bottom of shocks .
Thanks in advance also car jumps hard to keep control.
The rear bump stops are located above the upper control arms, right next to the shock absorber.
Sounds like you have blown rear shocks, and possibly broken coils.
I thought QX56s all had rear air-suspension (no coil springs) as stock.?
I have the same problem with my '08. I just bought a set of Arnott air springs to replace stock units. However, it will be at least a few more weeks before I get them installed.
I should add that as soon as I get those new Arnotts installed, I will get a 4-wheel alignment. I have found that if the rear is even a little out of alignment that the ride gets out of hand on the worst of bumps.
I also have a 2008 QX56 I Love my truck when I brought it, it had 58,000 miles it now has 162,000 miles I have the same issue. The problem seems to be a wheel alignment however I have a leak in my shocks as well so I couldn’t get a wheel alignment. So since my air compressor is still working I decided to go with the factory shocks. I couldn’t decide which other shocks I wanted to try. I just brought the shocks from the dealership $460 for the pair I’ll put them on next week and get a wheel alignment. Hopefully that will solve the problem I did learn that information from this sight. Another issue I have is my fuel gage stop working so I reset my trip meter after every fill up I need to get that fixed ?? other than that it runs like a dream still loving it just as much as the day I 1st brought it.....
You have three options, in my opinion:
  • go with OEM from Nissan -- a bit expensive
  • go with Arnott. I bought mine here, but the lock down is keeping me from getting them installed: Search Results For: AS-3284. Found 1 Items.
  • replace with Bilstein 4600, which is basically a B6 that many of us already install up front. Most that go this route also swap out the rear springs for something more stout, as the OEMs will sag without the air shocks. Search the forum for threads from people that have gone this direction for options on springs
hope that helps!
2006 QX56 and 2016 QX60
can I just do the shocks? what did you install?
Check out my below thread.
hope that helps!
hope that helps!
Quick update -- last fall I was able to get my Arnotts installed on our '08, along with the Bilsteins up front. I already had Bilsteins up front since about 10k miles, so no surprise there. The surprise was how much better the Arnotts are compared to OEM. Our QX56 definitely rides and handles better than when new.
Hey Ppointer, I know this is an old thread, but I'm wondering how the Arnott conversion worked for your rig. My daughter just had to convert from the air suspension using the Arnott C-3421 in the rear, and her Armada has some serious swaying in response to bumps. I'm thinking there may be something beefier that would work better.
What have you experienced with the Arnott?
Ah, just posted above. I had some issues right after the Arnotts were installed, so went to the Infiniti service center for diagnosis. Problems were attributed to worn out suspension bushings, including all four sway bar links and two of the rear control arms, and of course, a faulty alignment by the independent that had installed the new shocks. Problems were solved and QX now better than new. My suggestion is to have a Nissan or Infiniti service center take a look at her Armada ASAP.
MUCH appreciated!
Thanks!
Happy to help. Note that the AS-3284's I used are air shocks that bolted in to replace the OEM, rather than the conversion away from air shocks that your daughter chose. Still, I think checking the other suspension components and doing an alignment could potentially solve her problems.
1 - 20 of 20 Posts
