Are you certain the key blade is cut to the correct pattern? Have you tried the blade in the door to see if it works in that lock?
Yes, physical key locks and unlocks doors from the outside. Both fobs also fully work.Are you certain the key blade is cut to the correct pattern? Have you tried the blade in the door to see if it works in that lock?
