1 - 2 of 2 Posts
The light illuminates when pressed but you can tell the air doesn't change and outside smells still come in. This makes me think the actuator isn't working. Any idea what to check first, fuse or otherwise?
Thanks Michael
hello.
if your door actuator is stuck or unresponsive, you may need to replace it.
this is common among armadas and qx's of the same vintage, so it would behoove you to search the forum in the "problems" section to read more about this.
this was a quick 5 second search but there are quite a few discussions:
AC Actuator Replacement (this is an old post and the links are no longer working, but still has some info that may be helpful in removing)
1 - 2 of 2 Posts
