Hello,
New to the forum but have a few questions
Vehicle: 2010 nissan armada
Trim: platinum
Engine 5.6
What happened: So I had a transmission slip the other day slipped approx.: 4 times within 100 mile drive while in 4 wheel drive driving in a bunch of snow and ice.
The following day I started it up and the check engine light came on I took it to advanced and had the code read and he just simply showed me the message that read "tcm lost communication" he didn't tell me the code so I am going to go tomorrow and get it re read and pull the code.
So the kicker to this is since then I have put approx.: 150 miles on it and no slips or anything that I have noticed with the transmission but I didn't have it in 4x4 but 2 wheel drive. (Not sure if this makes a difference or not)
I checked the transmission fluid it's Def. Not red as it should be. More of a light brown color so that obviously needs attention at the least.
I called a few shops and they had a few different opinions:
1) bring it In to run more diagnostics but he said if it's not doing it now he would likely reset it and move on unless it persisted then bring it in and he'd do a transmission shop.
2) another shop wanted to look at it but said the tcm of this year is internal and they suggested replacing whole transmission with a used one for $2700 they had one on the shelf with 65k miles.
My question is. Has anyone ever experienced this and what was the outcome? Or any suggestions on what is going on with this?
I'll repost with the error codes once I have them.
Trim: platinum
Engine 5.6
