· Registered
Hi there,
I got a used 2011 Armada, I successfully started fixing up a few things including a broken door handle: [SOLVED] repair back handle | Nissan Armada & Infiniti QX56 Forums (clubarmada.com)
As I installed the new one (Amazon.com: XtremeAmazing Rear Tailgate Door Handle for Armada 2004-2015 : Automotive ) I realized there is some empty space between the camera and the door handle.
Fixture Gas Circle Auto part Composite material
The previous door handle (white) had a larger hole and had a piece of plastic to make it a perfect fit.
Rectangle Gas Automotive tire Bumper Wood
Here are the two side by side (white is the old handle):
Automotive tire Rectangle Gas Bumper Electronic device
Automotive tire Bumper Automotive exterior Gas Trunk
This is the piece of plastic the white handle had:
Automotive tire Road surface Wood Asphalt Automotive design
And it doesn't fit my new black handle.
I am thinking about cutting the extra plastic or finding some padding to avoid water getting in. Any other ideas/suggestions?
And I have another question (perhaps a separate thread?) about the back camera, the view is kinda low... at the bottom I can see the bumper I think... and it used to be like that with the previous handle. Any thoughts? Does yours look like this?
Rectangle Yellow Font Line Gas
· Administrator
here is a photo of the view from the back on a nissan oem camera.
Motor vehicle Hood Automotive tire Road surface Asphalt
this was taken off this video
i recall seeing this as well. i think its there so you know where your bumper is in relation to objects near it. would seem this is nissan's intended purpose.
i did the mod just as you did back in 2006. i think i bought an aftermarket camera as well, and put it in there and fabricated something to protect it from the elements.
· Registered
Thanks for the reply!
I wonder if gluing some glass in front could work instead of padding inside...
· Administrator
id think over time perhaps the side of the glass facing the camera could get dirty/dusty and could cloud the image from the camera. plus if something were to crack it, you'd have to remove the panel all over again. just my thoughts. if i recall there is nothing in front of the oem camera, so maybe nissan had a reason...
