21 - 32 of 32 Posts
replace the black one right bottom of pic
it is hard to pull it be carefull it has two hook on side I broke the old one when try to pull it
the fuse box dont say what is it I just see two big wires come from that corner just guessing that is going to starter
Dung, please tell me the year of your armada.
I am having the same issue with a 2012 armada. The relays are exactly the same as what you have posted and I'm trying to figure out if there is a starter relay as well. I can't find a wiring diagram that shows a label for each of the relays.
Can anyone help with that?
Discussion Starter #24
I replaced the starter 3 months ago and have not had an issue. The job was not as hard as everyone made it out to be. Even though I pulled the fuel pump fuse and started the car till it died there was still a bit of fuel spray when I disconnected at the fuel rail, I was told later to keep cranking it for a few more seconds. I did not disconnect the battery as was just careful w/ the large wire going to the starter.
I'll chime in and say thank you for posting the result of your effort and posting pictures! I've had the intermittent starting issue for at least 5 years. A new battery always seemed to remedy the situation, but as of yesterday, I get no start, crank at all. So I am exploring options and your thread puts replacing the starter near the top of my list (after the other, easier remedies).
thx
Here is a great video for the job,
I've seen posts about starting issues and decided to look into it a month ago. This Video is helpful and others on YouTube can be found too.
Does anyone know the OE brand for the starter off the top of their heads? I have this issue as well but noticed if I wait a second or two between on position and crank, then I have no issue. I have also replaced the battery and the aforementioned relay.
*Edit: Answered my own question - looks like Mitsubishi brand lol. What is a good replacement brand?
Search online for the FSM and there should be a spec sheet in the STR section.
There was for the older models anyway.
21 - 32 of 32 Posts
