1 - 1 of 1 Posts
I had a low beam bulb burn out this morning on the way to work. Are these sealed units or can the bulb be replaced? The owner manual says the high beam can be changed but the low beam bulb requires the dealer. I know you can access the area from the wheel well removing the plastic shroud.
1 - 1 of 1 Posts
