On a road trip this weekend I noticed that even when the AC light is not on, the AC is actually running and the compressor is running. Defrost mode is not on.
Modulating the inside temp to match the outside temp, I noticed that setting the temp to 67 degrees inside while hoping to run just the fan and keep airflow going resulted in freezing inside temp.
is it no longer possible to just have outside air flow?
The AC had not been on previously. I know in our pathfinder if you use the defrost you’d have to turn off the defrost and turn the truck off to reset and keep the ac compressor from coming on. (Super convenient....)
how do I keep the ac compressor off?
