Congrats! I agree with everything you said. My setup is a bit heavier than yours but within specifications, the Mada pulls it like a charm. 2019 Platinum
Hi. If you are asking me, I used what came with the Equalizer hitch. It is height adjustable.@MidnightArmada I plan on having the same TT and WDH setup with my 2020 Armada. Were you able to use the hitch that came with the e2, or did you have to upgrade to one with a drop?
Right on. That's what I'm hoping for so I don't have to buy extra stuff! Thanks!Hi. If you are asking me, I used what came with the Equalizer hitch. It is height adjustable.
Mine opens. No interference.For all of the setups pictured above, are you able to open the hatch while hitched up? I am wanting to know if the trailer jack post/crank interfere with the hatch when trying to open it.
Thanks.Mine opens. No interference.
Nice rig!! I'll be setup about the same. We are the proud new owners of a slightly used 2019 Armada platinum! The wife and I are picking up our TT, Jayco Jayflight 294QBS.Hello. I have a 2021 Armada SL 4X4. I tow a 2021 Winnebago Voyage 3033BH that dry is 7600lbs with a 660lb tongue weight and is 34ft total length. I use an Equalizer weight distribution/anti-sway hitch, and have had no problems at all. Yes you get pushed around a bit when it's quite windy, and yes the Armada porpoises a bit on large bumps, but otherwise the vehicle handles the load and tow extremely well. I do credit the Equalizer hitch for doing a great job at keeping the vehicle and trailer quite steady. It took me a while to get it set-up right, but once I did, it works very well. The trailer also has heavy duty suspension and brakes, which helps. With brake controller after trial and error I have it set at gain 6, boost 0. Sometimes I bump-up the boost to 1 on the highway, particularly in hilly terrain or at freeway speeds. I do tow with rear of the vehicle empty and we have been careful to not add a lot of weight with our gear inside the trailer, because I know I am on the upper limit of what the vehicle is rated for. That said, I was told by a Nissan employee that the tow capacities of their vehicles are purposely under-rated because they know people will push the limits. Note that in picture I did not yet have the hitch set-up properly. The hitch height was adjusted too high, and I had to also increase the tension on the load/sway bars. View attachment 52294
We towed alittle this weekend too. All around great experience except for, you guessed it, the automatic braking. I literally hate that feature. There should be a way to completely disable it. As it is, I have conditioned myself to turn off the traction control every time I hit the ignition. It's just a habit now. But, when you need to use the cruise control (with the adaptive cruise), the traction control has to be on...then I forget about the traction control and automatic braking (did it twice this weekend) and I move 3 feet in reverse only to have the brakes slammed on. I let a few words slip this weekend over that...We just got a chance to try out our 21 Armada towing our travel trailer (probably around 3200# loaded with a tongue weight under 400#). We do not have a WD hitch and given how well it towed without it, I'm not inclined to add one (we do have a sway control bar). The air suspension in the rear did a great job of leveling, as expected. My wife was able to drive much more comfortably than she was with our lighter TV and gas mileage wasn't much worse (we got 10.5 with a slight headwind). Really, my only complaint is -- why doesn't 'Tow Mode' turn off the rear automatic braking!?
Out of curiosity, why turn off traction control while towing? I only disable the rear automatic braking in the settings. I wouldn't mind that it didn't stay permanently disabled (I understand why they wouldn't want to do that) -- if it was only automatically disabled when you select 'tow mode'! Even better, it could detect the presence of the trailer (at a fixed distance behind the vehicle) when you start backing up and automatically disable.We towed alittle this weekend too. All around great experience except for, you guessed it, the automatic braking. I literally hate that feature. There should be a way to completely disable it. As it is, I have conditioned myself to turn off the traction control every time I hit the ignition. It's just a habit now. But, when you need to use the cruise control (with the adaptive cruise), the traction control has to be on...then I forget about the traction control and automatic braking (did it twice this weekend) and I move 3 feet in reverse only to have the brakes slammed on. I let a few words slip this weekend over that...
I turn off traction control all the time, not just while towing - because it disables the front and rear automatic braking. I didn't know there was a setting to disable the automatic braking - is it in the driver's menu? I loathe the front and rear automatic braking, in Dallas traffic, it's terrible up front. And I tend to back into parking spots, including the garage @ home, too many times, the sensors pickup the side of the house and slam on the brakes. It also happens with light poles, shopping cart corrals, etc. I've turned off the lane departure warnings - it stays off. I turned off all of the chimes and nannies that warn you when a wall or stationary object is getting close - I use my mirrors and the cameras for that, don't need the car yelling at me. But yes, when towing, the software should do two things: 1) recognize that a trailer is connected once the lights/brakes are plugged in and 2) recognize when "tow mode" is engaged - both of these instances should disable the rear automatic braking.Out of curiosity, why turn off traction control while towing? I only disable the rear automatic braking in the settings. I wouldn't mind that it didn't stay permanently disabled (I understand why they wouldn't want to do that) -- if it was only automatically disabled when you select 'tow mode'! Even better, it could detect the presence of the trailer (at a fixed distance behind the vehicle) when you start backing up and automatically disable.
