Just returned from a 2k mile trip, over 1500 of that was pulling my 28' camper (estimate 6000lbs loaded on this trip).
Perfect trip. Not one hiccup. Averaged 11.5mpg over the course of the trip.
I never had a false start and the limp mode (with no codes) did not pop up again. Every shift was crisp, the pulling power of this engine/tranny combo in an SUV still impresses me.
I came from a 7.3 F250 and 5.7 Tundra. This Armada pulls better hands down. I understand a modern 3/4 or 1 ton would bury it, I drive them at work daily, but I need an SUV.
There is not a better SUV for the family that regularly pulls campers or boats.
2019 Armada SL
Awesome, glad the beast did well! Can I ask, would you remember if the height of the Armada rear was lower, higher or the same after setting up the WDH? I am wondering if it best to try to get the rear the same height as when unloaded so that height sensor doesn't try to inflate or deflate the system?
@ODDs that's a tricky question. The Armada rear will level on it's own even without the WDH bars engaged, I'm sure it doesn't like this but it will do it.
With that said, I setup my bars very aggressive so that they can take some of the load off of the rear air-level system. Probably the easiest way that I can explain this, and it may seem counterintuitive....with the WDH bars engaged and the air level back up to height, your front fender-to-ground measurement should be within 1/4" of when the WDH bars are disengaged. The main purpose of the WDH is to transfer some weight back to the front wheels of the tow-vehicle. Yes a WDH by design helps to level the rear of the tow-vehicle and front of the camper, but it's main purpose is truly to get some weight back on the front wheels of the tow-vehicle.
You want your front fender-to-ground measurement as close to unloaded height as possible without going under. Too much weight distributed to the front axle of the tow-vehicle means that you're actually removing weight from the rear wheels, even more dangerous.
The rear air level system will always have some input, you'll never be able to setup a WDH so that there is virtually no tongue weight, you wouldn't want it setup that way anyway.
With all of that said, I have an Equalizer WDH and they have some of the best youtube videos explaining all of this.
When I pulled this same trailer with my Tundra I was able to get my front fender-to-ground measurement within 1/4" of unladen. But my rear fender-to-ground on the Tundra was still over 1" lower. Tongue weight is tongue weight, and when setup properly you're still going to have some.
I highly advise against going so aggressive with your WDH that the air-level doesn't need to do any work. Your torsion bars would likely have way too much load on them at that point. Camper A-frames have bent from a WDH doing too much of the work.
If you want to take more of the work off of your air-level system, consider the Coil-Rite airbags. I've been running them for about a year now. I air them up to 30psi when towing.
2019 Armada SL
@OBXPatrol , thanks for the info! I'll keep it in mind the next time I hitch up. Interesting about using additional airbags to assist the stock ones. I see how that could be any easy and inexpensive solution.
Another 600 mile roundtrip down this weekend. No issues with the limp mode or false starts again. Towing the camper again.
I've also had the battery sensor disconnected for a while. I'm beginning to think these are very sensitive to voltage, could be causing a lot of the other random issues people have had.
