Does VDC work with 4wd Low? I finally took my Armada off-roading, and while going up a steep incline with a diagonal rut across it, got stuck because two wheels didn't have much traction (one front, one rear). It was my understanding that the VDC would put power to the other two wheels, but the wheels in the air were just spinning. After a couple of tries, I backed down the hill and started to turn around. At that point, I noticed the VDC Off light was illuminated. Is this normal?
BTW, the stock Conti tires have absolutely no traction on loose dirt. Very disappointed. However, other than that, the truck did pretty good off road. When I got stuck, I had one front wheel about 18" off the ground, and the opposing rear wheel barely touching. Maybe I am expecting too much from the electronics.
