A/C problem?
2098 Views 5 Replies 5 Participants Last post by  scr38
There have been several posts here about the A/C not cooling well.
One possible cause hasn't been mentioned much.
I noticed that my A/C didn't seem to be blowing much air on lower speeds, and wasn't cooling as well as it used to. I checked my filters and they were very dirty. After changing filters I could really feel the difference, much more air at lower fan speeds.
If you haven't checked or changed your filters you should. Instructions are in the How To section here on ClubArmada.
Good point. I just had the dealer check my Armada. There is a TSB to replace the fan and readjust the ECM. The fan turns off when it shouldn't causing the air to blow warm and humid.
Well, something like that. Anyway, I'll see how the fix goes when they do it next week.
:temphot:
Checked the cabin air filters on my 2004 LE....none there. Is this a dual climate control option?
I'll probably order some from Mossy.
Yes they are an option and come standard with the Tech package.
Were can I find the TSB for the A/C cooling problem???
