1 - 2 of 2 Posts
2017 Armada Plat. Does anyone else have a noisy AC clutch? On mine it is pretty constant and it's not just when it engages, But from outside of the car there is a distinct rattle. The dealer could not hear it one time I had it serviced but did a second time and replaced it. Sound is still there, but not as bad. Not sure if that is how it sounds in normal operation or if there is still an issue.
Hello and swelcome.
Is this a used car to you? Ball bearings in a can sound is what you may be describing—this may be a sign of a bad compressor. It could also be a faulty pulley ? I mean if the dealer stated they replaced it and the issue is still there, then they didnt fix it and you should take it back.
1 - 2 of 2 Posts
