04ArmadaGalaxySE4x2 said:The factory fog lamp kit includes fog lamps, easy to follow directions, and the light switch stalk to control the fog lamps. It's a very easy install, it took me about 20 min. to install mine. Purchased mine off Ebay.
I pick up the Armada on Monday and just want to verify if ALL 2004 SEs come pre-wired for fog.04ArmadaGalaxySE4x2 said:The factory fog lamp kit includes fog lamps, easy to follow directions, and the light switch stalk to control the fog lamps. It's a very easy install, it took me about 20 min. to install mine. Purchased mine off Ebay.
from the sounds of it, this is a simple "plug n play" install for both signal stalk and fog lights.kytitan said:The new signal stalk will replace your old one. There are three phelps screws in the bottom of your stering colume cover. Remove these three screws and take the top cover off. The stalk is held in by two clips one at the bottom and one at the top. Gently pry the top and bottom clip up and pull the stalk out. Then just plug your new stalk in and replace the top cover.
If you want to make sure your armada is prewired just look under your front bumper. Around were the back of the fog lights would be there should be a wire with a plug on the end of it.
The fog lights for the titan are $169.15 at nissanparts247.com are you can call 1800-689-6560 and ask for Jamie. He will be able to tell you if the titan lights and armada lights are the same.
DO NOT pay your dealer to do this install for you. It should only take you 15 to 30 minutes to do it yourself. VERY EASY
Not only is their website kinda lame but $16 for Shipping to the Cincinnati area for fogs is 2x what it should be. Granted that is still a few $ cheaper then courtesynissan.com. My main complaint is you don't know what stage of processing the order is in or even if the item is in stock. If you sell items ONLINE then set up a system for customers to check up on their order. And BTW the $16 is for UPS ground, for that kind of money I probably would expect 2nd day air. And I really don't want to hear that a $8.00 'handling charge' for a probably 5 minute packing job is a valid expense.kytitan said:sorry nissanparts247.com
why do you say that?kytitan said:Wait untill you get the box with your fogs in it and open it up. You'll be like I paid almost $200.00 for THIS! lol
oh man, if an accountant can do........i can certainly do it!!! lolLFranklin said:I am an accountant, not a mechanic, and it only took me about 15 minutes to add the fog lights to my armada. The wires are already there. the lights hook up in about two minutes- literally just snap in. The stalk is easy, but getting the cover off around the steering wheel causes a few anixous moments. Just pry it off using a spatula or something on either side of the screw driver to keep it from damaging the plastic cover and go for it. It is easy. I am not sure it is worth it however. The fog lights are not effective, merely cosmetic.
Caps come of easily (instructions are included). I am NOT mechanically inclined and I was done in about 30 minutes. 25 minutes were spent trying to align and snap together the steering column cover (last step).MacFly said:oh man, if an accountant can do........i can certainly do it!!! lol![]()
i'm kidding!
do you have an SE? how easily does the "caps" come off? the ones that cover where the actual lights go into?
