Just replaced alternator, 6 months ago, both alternator and battery checks good. Immediately after installing, the power steering pump whined. Replaced fluid no whining, now after driving 4-8 miles, volts start bouncing to just below 12 volts, then goes back up to 14+.lights dim then brighten. Levels out then does it again. does stall occasionally when at light too long or at stop sign. Now after the volt bouncing begins it won't stop after 4-8 miles. Shut it off let it sit, starts fine, runs fine until warms up then back through the whole volt bouncing.. any suggestions? Also power steering has a small creeping leak but is on top of alternator, have noticed fluid on connections....
