For those that have installed an amp / sub in your Armada I have a couple questions.
How did you run your power from the battery? is there a hole in the firewall to go through? How long of a power cord do you need?
Also did you mount the amp in the rear storage comaprtment under the floor? Does it get to hot down there ???
I wanting to either do a 1 12" sub setup or 2 10" subs, also any comments on your setup
Thanks!
Thanks!
