1 - 20 of 20 Posts
How difficult is that? Doesn’t sound too bad.
Just take apart the left and right under dash areas, central trim, center console, center controls, and radio. Then wire in the stuff. Then close it all back up. Lol. Yeah, my point is it isnt plug and play and you can find cheaper options on Ebay. Maybe $150 for wireless phone mirroring.
Thanks for the information, that’s why I came here. Any recommendations for a mirroring device?
I installed the VLine VL2 Carplay/Android Interface from www.gromaudio.com. Works as advertised and retains all OE steering wheel audio controls. Also plug and play but it does require removing just about everything in the center console, shifter console and glove box to run the wiring harness.
Discussion Starter · #8 ·
I checked it out, could not find anything for a 2018 Armada. Does the kit require wire cutting?
No cutting in regards to connecting the wiring harness. The harness is 100% plug and play. They recommend placing the interface module in the glove box (easy access for usb updates). I didn’t like how it takes up all the space because of the wires running to the module so I got creative to mount it underneath the glove box.
I’m not sure of any major differences between the 17 and 18 Y62s but check with GromAudio to see if and when the VL2 might become available.
Have you had any issues since with your Vline yet?
The only issue I've encountered has to do more with my mobile service provider, Tmobile. There is this one particular dead spot in all of NY, actually on the Clearview Expwy in Queens whenever I'm out there. If I'm using Pandora, Amazon Music, iHeart, etc... because my iPhone cuts off for that second or two, then the Vline cuts off. I have to shut off the radio and turn it back on to signal the Vline to turn back on. Otherwise, it functions as if it was OEM since I can still use the audio controls on the steering wheel. I am hoping the next update from Grom Audio makes this a completely wireless setup.
Curious if anyone has put Apple Car play in their Armada’s successfully? I have a 2018 Armada and wanting this without messing up my electronics of the vehicle. I found this company awhile back but don’t know too much about. Any help is much appreciated.
Hello, my Armada is 12 years old now and I need to replace it. The built-in bluetooth is very static with my Samsung S22 and hard to hear on calls. I want to put in a newer Car radio with Andoird/IOS car play to take full advanatage of newer technology. I still would like the Steering controls to work to change volume, answer calls, and change stations. Any radios you guys recommend for a 2011 Aramada.
Grom SEEMS to have what you're looking for.
Sent from my SM-G996U1 using Tapatalk
1 - 20 of 20 Posts
