5th try- site advertising bugs keep crashing the page-
The recall identified over 100 faulty ground points in a diagram. So after the ground kit install, locate the ipdm, and ecu grounds, and add a wire from the unit chasis ground, to the vehicle frame. It will speed up the ecu. During routine maintenance, you will see screws and wires in strange (wtf) places. Just address them as time and patience permit. Observe that many of the grounds go into body sheet metal. None of which work as a ground... So any critical component/system should be tied into your add on ground circuit. Nissan has taken note of the increased reliability of the vehicle with the add on ground system, because I had a service manager tell me it voided the warranty. At 95,000 miles, I asked him what warranty would that be? (crickets chirping)(I then identified for him the 2008 recall. He was unfamiliar with it, and pointed out the defective ground system design. He got quiet at that point)
