Well my friends, just wanted to reopen a thread, for our new members.
It seems there was a big question on the Armada's towing capabilities. Nissan claims with the Tow Package, that it can tow 9100lbs. Some skeptics say that doesn't make sense, since the GVWR is around 7000lbs and the GCVWR (Armada + Trailer) is only around 14,000. They say theoretically, it should only be able to TOW around 7,000lbs.
So we need to address this a bit. Can anyone get an explanation from Nissan, or someone.. on how since the GVWR's don't change much from an Armada with or without the Tow Package............ How can the Armada without the Tow Package tow 7000lbs, and w/Tow Package, tow 9100lbs.
NOW.. here is MY personal scenario. I bought a 2005 Fleetwood Wilderness Advantage 34' Travel Trailer. Empty it weighs 7500lbs.. full, it weighs 9600lbs. I don't carry any liquid, only propane, and about 750lbs of cargo.. so I pull around 8500lbs. My Armada is a SUPERHERO pulling that thing. No problems.. I have a weight distribution Hitch, and the auto leveling rear suspension keeps me straight horizontally. I just came back from Albuquerque last week (May 3, 2006), went through Ludlow, CA where the temp was 95 degrees, traveling uphill, with the AC on, pulling my trailer.. I was passing Semi trucks and RV's, and my engine and Tranny temp gauge never even made it to the half mark. That is one tough cooling system.
I say, buy a big trailer with confidence.. until someone else says otherwise.. if you pull 8000lbs and your back end falls of, then you can go after Nissan for that one.
