Hi,
I have a 2009 Armada (SE). it's preowned and last 6 months it's with me. Recently i have noticed that when i stop the car at signal for few minutes in Drive mode, Transmission temperature going high- it is raching the last point just before H. when car moves this coming down to mid position. i am not towing anything with this car. can anyone please guide me - is it normal for this car? or anything i need to do to fix this. initially i suspect radiator fans but all are working fine.
Administrator
hi and welcome. i have seen your issue discussed here before. it is worth a little time to search the forum.
here are a couple of links but there is more discussion:
you are not towing as you say but this thread may be helpful:
Are you sure the Clutch Fan is working?
