1 - 2 of 2 Posts
Hello, I had a leak coming from what looked to be my automatic transmission oil cooler. Took it into the dealership, they said yep that was it, and they claimed to have replaced it but even after that it still kind of leaks. Just changed the oil again today and its leaking worse. Anyone else experience this, is it actually the automatic transmission oil cooler?
Thanks in advance.
49868
Thanks in advance. View attachment 49868
It's best to wipe everything down as much as you can and as dry as you can. Then check where the wetness reappears. It could be on that hose... just guessing at this point. Also smell... there is a difference in smell between oil and ATF.
ATF almost smells like Urine.
1 - 2 of 2 Posts
