Don't forget to make sure that your airbags on the rear are adjusted when measuring for drop. You will probably need the trailer hooked on and not sure if motor on or ignition turned on and/ or tow mode on to get the suspension adjusted and then measure how far off level your trailer is. That is your drop/raise.scr38 said:If you are pulling a trailer with tandam axles this is very important. You should select a drop that will have the trailer sitting level when connected with your normal load.
