21 - 29 of 29 Posts
Discussion Starter · #21 ·
Yes that the low pressure light that has always been on and no I didn’t try removing the cable. Should that be the next step.?
Administrator
you may lose radio presets and such but it may be an option to try. no guarantee it will bear fruit.
as for the low pressure tire lamp, you may have a faulty valve stem (TPMS) if your pressures are right. that could be causing an issue too.
Administrator
it was a shot..
you may have something going on that beyond the scope of simple troubleshooting. may be worth the diag fee to take it in to nissan. i'm not sure its possible to manually disable that particular beep. like I mentioned if this happened when you installed a new battery, you could have caused an electrical issue somewhere.
2007 QX56 RWD
Weird! I've not heard that particular chirping from mine. Yet.
I'm going to take a very wild guess and say it's related to the security system.
21 - 29 of 29 Posts
