Just found this forum and it's been alot of help so far. I have an 04 LE 4wd that I use to tow my 22 foot bowrider (around 5000lbs with gear, trailer, and fluids). It towes it fine but the boat's too small. We want to step up next season to a 26ft outboard deck boat which I figure will tip the scales at 8000 lbs with trailer gear and gas. Here's the questions - Can I tow that much without weight distribution - those type hitches aren't readily available nor recommended by surge brake trailer manufacturers. I figure the air bags help some and boats on trailers aren't typically tongue heavy. I'm assuming that the factory tow pkg is a class IV but typically I've seen class IV hitches with a 7500 lb rating unless using weight dist. Also has anyone done anything to help their towing power - chip, exhaust, intake,etc... - and really found that it helped with towing?
Thanks in advance for the help.
Daniel
Daniel
