1 - 20 of 20 Posts
We just purchased a 2015 Armada SL and bluetooth connectivty was listed on Specs, Ive looked online and it clearly says its available on all trims, but when I hit Settings-there is no option for Bluetooth. Please tell me it has it and I am overlooking something. Any help would be appreciated.
Administrator
if its not in the settings page as per the video, you dont have it.
you can take your vin, call any nissan dealer, and they can pull up all the specs your car has.
do you have 4X4? or navigation?
4-77 (pdf 278 of 510) starts off the procedure for setting up your bluetooth enabled phone for BT streaming. follow those instructions.
operators manual
Administrator
ok its possible you dont have bluetooth streaming (A2DP). again call a dealer and give them your VIN and they can tell you if bluetooth is included. some models will not have BT. I attached the operator's manual above that will show you how to access bluetooth if you have it. its not "hidden" or in some other location.
On the pad with the buttons under your screen, is there a "phone" button? What happens when you push that button? Also, are you trying to hook the phone up to make calls, stream music, or both? On my 2012, I can only make calls, not stream music. Don't know if that is the same for the 2015.
Administrator
streaming music requires A2DP - this is different than BT phone call use. the video is really self explanatory , as well as the operator's manual. some models do not have bluetooth , whilst some have phone call bluetooth only. also i would think if one did not have navigation they would most likely not have A2DP streaming, but this is speculation.
Discussion Starter · #11 ·
No phone button.
there is not a phone button.
48734
Administrator
did you call a local dealer and give them your vin? or follow the steps in the operator's manual?
it just seems you dont have the feature. were you told this feature existed? did you purchase from a 3rd party or dealer? you said you got the window sticker - does it specifically lists bluetooth streaming?
At this point, better off going with an aftermarket hands-free BT kits available that easily plugs into the aux port and/or 12v port.
This truck should have Bluetooth, it isn't the cheapie model. I'm guessing it doesn't have music streaming. My truck is a 2012, which has the older user interface. Plus, I have Nav, which the OP doesn't have. Else I'd be out coming up with a step by step for OP to use. Anybody on-line with a similar model and year, without Nav, to help this guy out?
You know what I do when I can't figure something like this out? Get my teenage kid out to do it for me. If you don't have a teenage kid, find one in the neighborhood. Those kids will figure any of this out, without the manual.
Discussion Starter · #15 ·
I bought it from a reputable Chrysler/Dodge/Jeep dealership , which also sells used cars. So they had a window sticker and every Spec I've looked up says this trim has Bluetooth. I have yet to contact my local Nissan dealer. I left a message with the salesman Saturday and he has yet to contact me back. I have a feeling he just going to say, "Sorry."
If there isn’t a phone button on the steering wheel, then your truck is definitely not equipped with BT.
Administrator
ok that makes sense. its a 3rd party dealer who have no idea of the trim options. they probably took the stats off some website.
im sure the dealer you bought from is reputable.
unfortunately its safe to say your car does not have it. there are a couple different options you can use, from getting a bluetooth adapter to going full aftermarket if you want to spend the coin.
That's a good question.....do you have a button on your steering wheel with a phone symbol on it?
This is Nissan we’re talking about. The audio systems in our trucks are so outdated when compared to other manufacturers. It took the 2020 QX80 to finally have CarPlay/Android Auto and in typical Nissan fashion, still not available on the 2020 Armada.
I had a pathfinder 2014 with the same problem back then ( and no idea on those days ) now I got a 2011 armada with same problem, the issue is the Bluetooth interface , small black plastic box on top of the main audio module underneath the passenger seat , disconnect turn the car on and off , reconnect this and turn on and try now, if doesn’t show up on your menu options ,Bluetooth modulen needs to be replace
Note: 2 indicators that confirm you do have Bluetooth (just for phone calls ) first: you have the phone button on the steering wheel , second see the small hole that says “mic” on top of the rear view mirror
Good Luck!!!
1 - 20 of 20 Posts
