I haven't had your problem with my 06. Do you see the same problems when controlling the stereo from the steering wheel? If so, the stereo face plate could be part of a larger problem.whitetail34 said:
I haven't had your problem with my 06. Do you see the same problems when controlling the stereo from the steering wheel? If so, the stereo face plate could be part of a larger problem.whitetail34 said:Drove '05 LE that was new on lot = had malfunctioning stereo on test drive so drove and bought '06 LE that proved to have same problem once left lot. Problem is that stereo doesn't respond to controls at times and presets don't work on stereo among other things. Anyone else relate same problem? Dealership says they haven't seen this before but I doubt I drove the only two with this problem. Now...2 wks later and still waiting on new stereo face plate. So much for that "new car feel".
Nope. No problems like that. First I've heard of them. How are the presets not working? Are you having problems programing them? Do they loose their memory after a few tries? Etc.whitetail34 said:Drove '05 LE that was new on lot = had malfunctioning stereo on test drive so drove and bought '06 LE that proved to have same problem once left lot. Problem is that stereo doesn't respond to controls at times and presets don't work on stereo among other things. Anyone else relate same problem? Dealership says they haven't seen this before but I doubt I drove the only two with this problem. Now...2 wks later and still waiting on new stereo face plate. So much for that "new car feel".
When switch from FM to XM or vice-versa and go back to FM the presets are lost. Today new problem = have to turn volume up to 12 just to barely hear it!!! Dealership says the face plate for radio is on back-order b/c Nissan factory is having to replace their supply due to problems. Thanks.92TripleBlack said:Nope. No problems like that. First I've heard of them. How are the presets not working? Are you having problems programing them? Do they loose their memory after a few tries? Etc.![]()
92TripleBlack said:Yep, you have a short. Probably just need a new head unit.![]()
Possibly. They will probably have to remove the player and then take it apart.B2NKR1 said:If its a short, can CDs that are in the unit be retrieved?? This problem just happened to me tonight. Driving along, listening to my MP3s and I hear a soft pop from the speakers and no more sound. Not only no sound, but no radio, no anything. Only thing I see in the display is the time.
B2NKR1: Did you get this resolved? Exact same thing happened to me tonight while playing MP3s. Our LE's just 4 weeks old!B2NKR1 said:If its a short, can CDs that are in the unit be retrieved?? This problem just happened to me tonight. Driving along, listening to my MP3s and I hear a soft pop from the speakers and no more sound. Not only no sound, but no radio, no anything. Only thing I see in the display is the time.
With an '06 I wouldn't even have trouble myself wit trying to fix it or reset it.armaDad02 said:Have a '06 Armada SE w/ bose system w/ dvd. First problem at 3 weeks old. While showing off to my brother-in-law stereo controls on steering wheel all of the radio turned off except the clock. Tried a quick fix by turning the car off and then on. NOPE. I ended up pulling all the fuses relating to the radio. 2 fuses inside, infront of front passenger, I think it's the fuse labeled AUDIO (10 amp) and SUBWOOFER (15 amp) and 1 in the engine bay labeled RADIO (20 amp). None of the fuses were broke, put them back in and everything worked again. Called my dealer. I was told that they have never heared of that happening to any owners and that the mp3 version is new for '06. Everything was working since then until this Monday. All weekend the radio worked perfectly. Switching from all modes.. i mean all modes from radio, to dvd, to dvd with only headphones, to the cd player playing audio cd to mp3. It finally died when we get to our destination (3 hours of driving). I was listening to CD (mp3) switched to RADIO then when I switch to CD the screen showed "PRESS EJECT BUTTON" that was the end of the CD player. Everything else works except CD player. Nissan will replace radio.
