Hi all, I’ve found a very strange issue with my 2019 Armada. After installing an Impulse break controller, seemingly randomly the car won’t start. When this happens, there is absolutely no power going to the car whatsoever — no lights, no clicking, nothing — then randomly, after a few minutes to hours, it starts again. When I was able to drive it to get the battery tested, they said everything on the battery and alternator is good but that I’m getting slightly low voltage to the starter. The weirdest part to me is that it seemingly recharges itself without a jump (although a jump expedites this) and will eventually restart again. The only thing plugged into the Armada is the brake controller. This happens even when the trailer isn’t connected. Are there any common culprits? Anything I can do to troubleshoot? Thanks!
Hi Alicia,
This seems to be a common issue with Armada's.
I replaced the brake sensor which is a very inexpensive and DIY fix.
There is a YouTube video on how to do this. I did this about 8 months ago and have had no issues until now.
So now I'm wondering if its something else is going on, that's why I'm on the forums searching for other possibilities.
My battery and charging system have been checked out as good .
Sometimes when this occurs you simply wait anywhere between 30-45 minutes then the car will start up.
Please be aware of mechanics wanting to replace the starter and or battery if they check out good.
Auto Zone/Walmart will check out your system for free.
I have also seen a YouTube video with this type of problem where the IPDM (Fuse Box) is replaced for this type of problem. This of course is an expensive fix so I'm not going to invest until I'm sure this is the cause of these starting issues.
For now I have bought a very strong Jump Starter that I keep in the vehicle in case this happens while I'm out on the road. Amazon sells the Yesper YJS40 1450Amp starter for about $100.
I wish this information helps you out somewhat. If you find a better solution please advise me ASAP.
Kind Regards,
Randy
