I have not read much at all about this being an issue, but I heard that for whatever reason Armada cats have the tendency to self destruct and get sucked into the engine causing engine failure...? I am assuming that this is not common as I was previously led to believe? Thanks in advance.
Has this happened? Yes. Is it common? No. And typically it is caused by something else going on with the car, such as a misfire condition, that was allowed to go on for too long without being fixed. I've also heard low fuel pressure can cause a cat to clog up due to running too lean and then come apart and get sucked back into the engine. What is common is that 1st Gen Armadas have a tendency to crack exhaust manifolds. This happened on my 2006 Armada, fortunately before the emissions warranty had expired. Hasn't happened on the 2012.
Gotcha. Thanks for the response. There is a youtube video about nissans and the guy (car wizard) claimed that armadas were known for failing cats... thought that sounded odd since you usually hear about the headers—not cats.
Vendor
The problem is that the header and cat are 1 piece.. headers are very prone to cracking and when it does crack it messes up the fuel mixture which then causes the cat to fail.
