1 - 3 of 3 Posts
Hello,
I have a 2006 qx56
I’m having an issue with its check engine-
I changed the fuel pump and made sure the leveler sensor is reading and yet the check engine is still on- meanwhile the car drives perfectly fine. Also- my dash is haywire lights come on and off and all sorts of craziness
sounds like you have some electrical issues. since your check engine lamp is still on, did you/can you pull any codes from the obd port?
I’m still pulling codes with obd, however my dash is all messed up, lights come on and off gives gas inaccurate readings sometimes- but after changing the pump car drives 10000x better- but I still get check engine.
1 - 3 of 3 Posts
