1 - 3 of 3 Posts
Hello guys! I have just bought a 2009 QX56, and after driving few hundred miles all of a sudden the 'check engine soon' light flashed up. After this had happened, I pulled to the side of the road, looked at the engine, and I saw smoke coming off. It turned out to be cooler (it has got small holes, kind of exploaded ). However the water temperature was alright all the way. Also, water came out from exhaust. Engine sound is also different, as if one cylinder woudn't be working.
I think it has got something to do with the head gasket.
Does any of you have some similar experience? If so, I would really appreciate if you shared your eperience with me!
Thank you in advance,
Tomas
Is the check engine light on? Flashing?
What codes from the check engine light?
Pics?
What does the oil look like?
Any oil in the coolant?
1 - 3 of 3 Posts
