http://www.knfilters.com/search/product.aspx?Prod=63-6012
I was speaking to a friend of mine and he purchased the Volant Cold Air Intake for his F-150. He informed me that he gain about 15 extra HP (not sure how he knows since he didnt get it dyno'ed, but oh well); but did notice that the performance was greater and towing was easier; also he says that he gained about 4 more extra MPG in his everyday driving... Going forward with this, I was looking at getting an air kit for my Armada.
I know there are many different Cold/Cool Air kits out there. Just wanted to see if others here has had experience with air kits like above.
If so, which brand did you get and what are the results should I expect? Better MPG, HP, etc. ? As well, what problems did you have? From installing or having the system adjusted for the fuel air mixture? etc..
Thanks,
ConnRadd
WOW, thanks....
This is what I was looking for... Now I wonder if they have one for the Armada?!?! May also buy this one for my F-150.
Shailey:
The Volant that I installed I got from got_titan and it is the generation 2 and I bought the ram air system separately. By the way, I want to say thank you to John for helping me out and getting it to me quickly. He included a couple of extra parts for me and I greatly appreciate it. The install was very simple since I only had to put one bolt in the bottom of the box, the hardest part was stretching the new silicone connector over the intake tube. LOL Now then, the sound is very loud! It also had a pretty good vibration when accelerating a little faster than normal. Under WOT it had some serious volume and the truck responded quickly. Results: 10 hp and 14 lbs of torque.
The Volant for the Armada is the same as the one for the Titan. Check with the dealers in our sponsors section for the Volant.
ggeorgie said:
SCR, did you install the ram scope system for the volan too ?
No, I didn't. I think it is useless. You might could get a very slight boost if you are driving 100 MPH!
