We have the best way to fix the cracked manifold issue on the Armada and QX56. Look us up and give me a call. Www.cajunbpipes.com
No installs for me just not enough time, I'm to busy with the fulltime job and welding bpipes on the days off. There are several customers in your area and NC that have had headers installed. I know a guy in Virginia who has done several header installs. Best thing to do is make a post on here and Titantalk.com and ask for a installer in your area.Always wanted to do this.. two things generally stand in my way... a) I don't have the capacity in tooling, equipment, or time, and b) no local shop here would touch this job with a 10 foot pole.
Do you guys do installations at your shop? Louisiana wouldn't be a bad road trip![]()
I have thought this through and I am not going to do it myself.No installs for me just not enough time, I'm to busy with the fulltime job and welding bpipes on the days off. There are several customers in your area and NC that have had headers installed. I know a guy in Virginia who has done several header installs. Best thing to do is make a post on here and Titantalk.com and ask for a installer in your area.
As far as tools it does not take a lot of speciality stuff. All you need is a floor jack and jack stands, 14mm sockets, wrenchs and extensions thats about it. A 14mm ratcheting wrench is my #1 tool with this header job. 2wd's are not that horrible but the 4wd can be a little of a pain with the extra stuff in the way. What a difference the Stage 1 or 2 makes in power without loosing any mpg...![]()
Your missing out then.I have thought this through and I am not going to do it myself.
I did this myself last year. Took about 8-9 hours total. It is a pretty straightforward job - as in not complicated. It is just a tight space to work in. If I had a lift and everything was accessible it would probably take an hour or two without stuck or broken nuts/bolts.A 14mm ratcheting wrench is my #1 tool
Absolutely use the OEM gaskets! No modifications needed. Jeff gives the OEM gasket part numbers on his website:I have an 06 Armada in California. Installing JBA shorties. I notice you recommend OEM gaskets for your kits. Should I use OEM gaskets with the shorties? Do I need to make any modifications to the headers if I use OEM gaskets. Thanks for the help.
