I just installed the Gen3 Volant and knocked it out in 30 minutes. The cover's definately sealed this time around. As we all know, the Gen2 didn't seal well in the middle. I had the Gen2 prior to this install and noticed six differences on the Gen3. A) The intake pipe between the box and the throttle body is slightly larger in diameter by about 3-4mm. I can tell by eyeballing the Gen3 & Gen2 side by side. B) The rubber sleeve that came with the Gen3 that connects the throttle body and the intake pipe is larger in diameter too, to accomodate the larger pipe. C) The Volant logo is not on the rubber sleeve like the Gen2 had. D) The intake pipe now has brass threaded sleeves so you can use the OEM screws to mount the MAF instead of the self tapping screws that came with the Gen2. For some odd reason Volant still gave me self tapping screws with my Gen3. I had to dig out my OEM screws because Volant didn't supply them. Hopefully you kept yours if you installed a Gen2 prior. They also gave me an extra rubber sealing gasket that you put on the lip of the intake hole to seal the gap between the box and the fender. E)The intake box has a different design next to the hole where the box meets the hole in the fender wall. F) Last but not least....the chrome cover looks awesome and sits in a pocket around the whole perimeter of the intake box so it sits flush with the top of the box. It's definately stiffer which makes it seal better than the Gen2's plastic cover which made it bend easily when snugged down at the corners. I did notice if you start tightening the screws on the lid down to the point where you're squishing the foam pad under the cover, the corners tend to bend down which then arcs the middle between the screws up in the middle like the Gen2 did. It won't bend up as much because the new cover's metal. TIP....Before you put the cover on, slightly flex it like a "U". DON'T bend it literally like a "U"......just enough where there's a slight concave bend so when you put the lid on, the lid's resting on its bend in the middle. This way, when you tighten the corners down, the middle will stay down reducing the chance of a leak if you tighten it more than normal. Also, don't over tighten the screws because the foam pad will squish which will also bend the corners down. Check out the pic when I got done cleaning the whole engine bay. Hope this helps!!
