Most might already be aware of this but the door jam light switch on all 4 of the Armada's doors uses the single screw that holds it in place also as the electrical ground. After purchasing a new light switch and moving it to different doors I learned this valuable piece of knowledge. I had to order the specific screw to fix the issue. Now my rear driver side door activates the interior lights consistently and without flashing.
As you can see the Phillips head on the old screw was starting to strip. Because I'm holding it by the threads you can't see where a tiny band near the bottom became discolored (and I assume the source of this bolt no longer being a proper ground).
Here's the old screw and the part number:
